oil pressure gauge question
99gst_racer
Moderator
12,010
1,707
Apr 5, 2003
Coloma, Michigan
I will be purchasing a new oil pressure gauge next week, but I have one question. Should I get one that reads up to 100PSI or 150PSI? I figured the 100 would be sufficient, but I dont know if our cars tipically read over 100 or not. There is no price difference, so I just need to know if I'll ever break 100 PSI with my car. Thanks. :dsm:
I wondered that too...It was hard enough for me to find a good electronic gauge that went to 100psi...I couldn't find any in my price range that went up to 150. I would assume our cars wouldn't spend much time around 100, but I'm not sure. I really couldn't find any good info on that. I've got one that reads up to 100psi, but I haven't started up the motor yet.
RamenPride said:
on cold mornings my oil pressure will go above 100psi until everything gets warmed up
VDO makes electrical gauges that go to 150psi
Whats the highest you've seen on a cold morning? What is a good average of your oil pressure after it's warmed up?
my gauge only goes to 100psi, so it's hard to say
when warmed up, i get about 17-20psi at idle, about 70psi while cruising on the highway using Castrol Syntec 10W-40
Autometer makes some 150psi units. I got mine as a 150, it rarely reads over 100 though, just when its cold and maybe at really high revs. Usual cruising pressure for me was RPM*2/100. My idle pressure was usually <10psi.
