Oil Pressure drop on open throttle?
kidmet
Supporting Member
217
21
Jul 23, 2012
Aurora, Colorado
Anyone know reasons that my pressure would drop when reving in the driveway? Same happens when driving and you press the gas. Don't want to damage the motor, so I haven't drive much at all. A couple houses maybe.
Probably should try and detail the problem more. Sounds like something is stuck inside one of the oil galleys. Check your oil pan.
The oil pressure gauge never went above zero throughout the entire video, and the light comes on everytime it's off idle. I would say it's unlikely that both sending units are bad.
Is there a dent in the bottom of your oil pan perhaps?
I'd get a oil pressure tester (mechanical gauge) and see what the oil pressure readings are. A damaged or plugged up pickup may cause your issue.
