Oil pressure drop on left turns
fiveSFE
153
May 20, 2005
Tucson, Arizona
My car is a 91 GVR4, mods are a 93 7bolt with 220k, fmic, exhaust, 255lph, fpr, fidanza flywheel, xtd stage 4 clutch. running 15psi.
Yesterday when driving home, I was making a left turn from a stop, My oil pressure shot up to 80(which is normal), but half way threw the turn it very quickly dropped down to 60psi, after the turn shot back up to 80psi.
This was the first time i noticed it, I tried to replicate and was only able to do it once more, The oil psi dropped 20 psi mid left turn again.
oil left is about half way between the two marks on the dipstick. Im thinking the oil is sloshing away from the pickup during left turn. But im also very paranoid about putting in a 7bolt into this car.
crankwalk? or problem with oil filter housing gasket or oil filter housing o-ring. im having a similar issue right now. have any oil leaks? any mods recently?
The last thing ive done were the brakes on all 4 corners, so thats not it, before that I did the oil pan gasket and turbo drain. Im still leaking from somewhere(dripping oil off xfer case). But I keep a pretty close eye on it.
Assuming you have an electrical pressure sensor check your connections (wiggle the wire while someone watches your gauge). Clean and re-seat the connections if necessary.
don't trust the dipstick unless you KNOW it's an OEM mitsu unit, idiot ricers put parts store sticks in all the time making for erroneous readings.
also try and run 1/2 qt over the full mark and see if it still does it (test this fast and in one day/session)
if still persists, drop the pan and inspect the pickup, maybe there's trash, bad/missin pan baffle, oil pump going out etc...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
