Oil on Timing Belt PIC Link Included
Dude take a picture of your belt then and not your engine. Its probably not your timing belt, but something else on its way around that is dropping oil on it. Make sure all your lines are hooked up and that your oil filter hasnt worked its way loose.
sorry, i took the pic for a record pic and noticed the oil when downloading. I don't have enough space in "my gallery" to upload more pics. How do I delete current pics to make room for a better one of the t-belt? Oil filter is fine and can't see any oil under the car on the oil pan, sending unit, bolts, or anything. Could it be rubbing and not oil?
check your cam seals I just had that problem with oil on my timing belt and now im doing another timing belt. Also check your power steering lines I has one that only leaked when i turned. Hope that helps.
