Oil Leak Issue
FoXracing82085
95
Nov 23, 2010
Lynchburg, Virginia
Please forgive me for posting this issue again but the first time this was posted I didn't get any responses to my issue.
I replaced my valve cover, valve cover gasket, oil pan, oil pan gasket, and oil filter trying to fix my oil leak in all possible ways that was easy. I also used the permatex on my gaskets as well.
However I still have an oil leak from around the oil filter area. Any clue on where it could be leaking from? Could it be the oil filter housing itself?
:idontknow:
There is a o ring seal in the back of the oil cooler housing that the oil filter screws on to . To get to it you need to remove the oil filter then use a 24mm socket to remove the threaded bolt/ stud that holds down the oil cooler .also remove the 2 coolant hoses off the cooler . remove the orange color o ring and replace , Note Dealer item.
:idontknow:
Something to check too is the oil filter gasket that comes on the filter. Sometimes when you change your oil filter the gasket thats on it sticks to the block then when you put the new filter on with its gasket the two together will leak. Its a pain to check because you have to drain the oil but my money's on that.
Possibly the crank seal or something in the timing cover leaking and running out of the bottom of the cover. Hard to tell with out seeing.
I know its an old thread w. e., but What is this orange o-ring properly called or what's the dealer part #? I believe thats what broke on my car and oil was just dripping like crazy i basically lost all of it =/...thanks!
If it's the OFH o-ring you can use the rubber o-ring from your oil filter if no dealers have them in stock. But most parts stores sell a uv dye you put into the oil and run the car while shinning blacklights on the engine, the oil leak will be a neon green.:thumb:
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
