oil filter/oil housing problem
mindset
1,853
7
Jan 3, 2009
Brunswick, Ohio
Ok, I have a big leak. It seems as if it was coming from the oil filter. I pulled off the oil filter and the gasket/o-ring was "stretched" and wasn't on the filter. The filter was a Napa filter. I read on a different thread of a bad oil filter housing, that the part where you screw the filter on was loose. I don't know the exact terminology for that specific part but its what you screw the filter on to. Understand? Turns out, I went to go see how loose it was and I was able to turn the part with my hands, so I tightened it. Is it supposed to be that loose? And should I tighten it down with a wrench. I don't want to damage that oil filter housing. This leak is pretty bad so any help is greatly appreciated.
Thanks.
I will also post pictures if the above sounds confusing. Let me know.
Yes tighten it down with a wrench, it should not be loose. It will just happen again if its not tighten with a wrench.
Ok, do you think that will help aiding the leak? And do you know if there is a different gasket that belongs on the housing part, not the filter? If it's running, it loses about a quart every 15 seconds :banghead:
Your also going to want to replace this gasket. Read this thread and you'll find the part number for it. I ended up having to order it from JNZtuning. Could only find that part OEM. Its the orange gasket, you need to split the oil filter housing to see it.
http://www.dsmtuners.com/forums/newbie-forum/322586-parts-identification.html
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
