tschuhly
- 230
- 70
- Nov 6, 2024
York,
Pennsylvania
Let me start off by saying that I am fairly new to the DSM world and am learning as I go.
So here is the issue:
I purchased a car that was in pieces and I am trying to get it back together for daily driving, though it may make around 400hp. I just noticed that the water pipe that came with it has the tube offshoot for a water cooled OFH. The engine that came with it came with the forward facing OFH (I believe for the Mighty Max) and the male part that the filter screws to is too short for the water cooler that sandwiches between the OFH and the filter. I don't know if it has the ports for externally cooling. How should I go about resolving this?
-A. I could potentially cut the coolant tube offshoot and weld it closed and then try to find a way to make an external cooled OFH (I bought an OEM transmission cooler for this potential idea)
-B. Should I buy a OFH that is meant for the water cooling and swap them since I have all of the parts needed for a water cooled setup?
-C. Any other option that I don't know about because I am but a mere peasant noob among wise DSM masters.
