spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
I've looked around and haven't found the answer I'm searching for. I bought a 6 bolt long block yesterday, but I'm going to use my 7 bolt head instead of the 6 bolt head. My 6 bolt OFH has all the ports capped with threaded inserts since the original setup had the oil feed line hooked to the head. My 7 bolt head has this port on the head capped. Since the 6 bolt OFH is capped, I really don't want to mess with it, so if I use the feed port on the 7 bolt head, is there anything I have to do to the head for it to work right or is it ready as soon as I pull the plug from it?
6 bolt head:
7 bolt head:
Also, which of these ports is actually better for the turbo? I know the OFH port delivers direct oil unlike the head port, but the head port is a less complicated and shorter route to run.
6 bolt head:
7 bolt head:
