2G New oil feed line
Dsmdaniel18
Jun 12, 2018
West Valley City, Utah
I got a new oil line and I ran into a problem the new one came with a 90% angle pipe that runs into this black round thing and it won’t tighten anymore it’s still loose I’m wondering what I can do to get past that
That's the oil pressure dummy light. You can remove it to finish tightening your 90* fitting. Make sure you angle it in such a way that it doesn't interfere with the oil pressure switch and the line coming off of it. Don't over tighten the oil pressure switch when reinstalling.
Unscrew it again and flip its position 180degrees before you screw it in again
Don't over tighten it, you risk cracking the housing where it mounts to the block
Thanks do you guys know what size it is?
