2g oil feed line
If i remember correctly the restrictor is build into the turbo. If you wanted, you could just run a ss oil line straight from the oil pump housing to the turbo and call it a day. :thumb:
if you add oil restrictor to your stock t25 turbo it would have two restrictors, the one build in to the turbo and the one you added. there is no restrictor build into the the oil lines. the restrictor is build into to the turbo. Basically your turbo would be starving for oil which is not good if you added another restrictor. The 14b turbos though do require a restrictor build into to the oil line.
I know what your talking about. Thats not a restrictor. All that does is what you said, connect the two lines together. if you want you can PM because i have an extra ss oil feed line that come with AN- fitting for the t25.
