1G Oil feed line HELP
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
Hello I have big problem with my oil feed line to head , I screwed the screw badly and destroyed the thread
here is a pic
the thread is broken but in the middle is already good
the bolt spins in place and i dont know what to do :(
I have a few ideas
A: Buy longer banjo bolt 10x1.25
B: Buy helicoil and repair the thread but I can not do it..
C: Buy long bolt 10x1.25 and screw it to head and buy Oil feed line from oil filter location and install it.
What should i do ?
I have had success using a heli-coil kit. If you have a drill, drill bit and the heli-coil kit then there is no reason why you can't do it yourself. You could also drill and tap the hole for a larger bolt. However, the first option is by far the easiest. I would crank the car for a few seconds to let the oil flow flush out any metal shavings from the hole.
here is a pic
I have a few ideas
What should i do ?
Do not try and install a longer banjo. You will block the feed to the exhaust cam. Best option is helicoil. It’s not hard
Ok thank u , it will be a little hard to drill in this place..
it will be hard to drill straight
