Oil dummy light terminal and oil feed ?
davidalindsey
343
3
Nov 5, 2008
Norfolk, Virginia
Okay so wil trying to fix a OFH adapter leak, I accidentally broke of the electrical terminal for the dummy light. Does anyone know where I can get the little electrical terminal at?
Also the fitting on the OFH leaks just a little bit. I was wonder if it would be okay to use thread sealent or red locktite on it.
For the adapter, try tightening a bit more. I did not use any on mine and mine is not leaking, but if it still persists, take it out and put some teflon tape, or thread sealant all around the threads.
For the dummy light, I just bought a generic cigarette lighter from auto zone for like $7.00.
The connection on the back is the exact same shape as the dummy light connector.
I tightend the adapter one full rotation more. I used a rubber mallet to tighten it as far as it would go.
In the process I broke the line so now I am waiting from ExtremePSI to send me my $8.00 line. I will know monday if its tight enough. If it still leaks I guess I will use wite thread sealent.
