Odd valve cover thing
pauleyman
DSM Wiseman
11,701
5,548
Nov 19, 2011
oklahoma city, Oklahoma
Ok I've done dozens of installs. I don't even think about it. I went to put the valve cover on this car and it wouldn't sit flush. I double checked it a few times and finally just put the bolts in and sucked it down. Gasket wouldn't even touch the head at first. Never seen this. I didn't have to crank the bolts down to get it down but it wasn't like usual. Comments?
The only thing I can think of (outside of cam towers or their bolts not being torqued down but you'd instantly know that) is the spark plug seals are thicker than "normal". What brand? My set is Mahle or some such, and I've not seen seals that fat and round before.
Wonder if the gasket came out of the track a little or twisted a bit in the track. I'd be curious how it looks if you pulled it back off. I've never had that happen even with new gaskets. Just recently used the felpro one myself too.
I did have a similar issue happen when I was sent the wrong gasket by RockAuto. It was for a black hyundai VC and was way too thick.
I pulled it a couple times. It wasn't twisted. I also thought the hyundai gaskets are identical. Just the bolt holes are deeper.
I’ll have to dig through my build thread to find it, but it wasn’t identical at all. I had to fight them to get me the actual one from Felpro and it went in like butter.
Edit: Found it. Here's comparison pictures.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
