Resolved NPR Piston Rings won’t fit
xv_dsm
4
Sep 3, 2019
North Charleston, South Carolina
So I finally bought a oem piston since one of the original was damaged and it’s the same size as the others. I went along and purchased some NPR Piston Rings for it but when I went to put the oil rings in, with only 2 in, and they were already tight and the third ring wouldn’t even go in. It did this with the other 3 pistons. I wondering if I’m doing anything wrong or if I should check something else or if I simply have the wrong part. If I have the wrong part then is anybody willing to buy it off me I can’t find the receipt.
@DSMPT I had a feeling that’s what it was for. I read that mitsubishi oem pistons are very reliable do you know how the two work and which one would you prefer ?
2g pistons have higher compression ratio and lager diameter wrist pins than 1g 6 bolt. If you have 2g pistons, get a ring set for 2g pistons. that would be the easiest and cheapest.
2g pistons have higher compression ratio and lager diameter wrist pins than 1g's. If you have 2g pistons, get a ring set for 2g pistons. that would be the easiest and cheapest.
thanks you were really helpful.
