Noob Goin Honda to DSM
1G King Koopa
48
Sep 23, 2010
Crown Point, Indiana
So im trading a 1990 gsx with some mods and a lot just done to fix it the dudes addin cash on top but like i said im a noob to DSMs so what kind of stuff should i look out for and any tips would be great.
Check the oil cap, notorious for leaking. Check the timing belt. There is 2 bolts on the oil pan that if installed incorrectly can wear a grove into it. Check the CV bolts every dsm I have purchased has had a torn CV boot. Make sure when your driving it to shift in and out of all the gears a couple of times at different rev ranges. At lot of the ones I test drove had bad synchros and killed the deal when I asked the seller to come down on the price.
Its an AWD so get underneath it and check the transfer case for leakage. I would do that after driving it as the owner may have wiped it clean to hide the problem. It could be a haggling point, but most often you can get this fixed by the dealer as it was a recall.
What 2 bolts on the oil pan are you talkin about? Im bout to be putting mine back together and i would like to keep from doing that.
Bring a compression tester with you and check it's compression! If it has low compression then you know it will be a long road ahead of you. If the compression is good on it then you know it has a healthy engine atleast.
Yeah, dont jump right in and do ghetto fixes, im in the middle of a full engine rebuild doing it the right way because i did ghetto quick fixes.
