Tiki2777
- 1,104
- 147
- Oct 9, 2011
Omaha,
Nebraska
Ok guys, I'm in a bit of a doozy... I'm putting together my 6 bolt engine build and I'm hitting a giant wall with my valve to piston clearance. For starters I have 9.0:1 Manley pistons onto Manley H beam rods, bored .020 over. My ptw is .0035 as per Manley specs. Now...onto the issue:
We clayed the pistons to check valve clearance. The cams I'm using for this are fp4rs. The block was decked 6 thousandths and the head was decked 3 thousandths. Mind you I have not checked the actual height of both the head and the block because of lack of calipers big enough, but I may be getting some from a friend soon. The piston sticks out at tdc above the deck at about 8 thousandths. I'm planning to run my new cometic .051 gasket and to test the clay we used my toast .052 Mitsubishi gasket.
When first claying the pistons. We found that the intake was a hair away from smacking the piston and the exhaust was about 20 thousandths of clearance...so in order to avoid donation issues and reordering gaskets I took the pistons to get fly cut a tenth of an inch deep (100 thousandth cut to ensure it clears both intake and exhaust) and turning the engine over was easy and it did not bind, we did the clay test three times before pulling the slugs.
Now after reinstalling fly cut pistons, we redid the clay test almost 5/6 times...here's where it gets weird. The intake is still a hair from clearing the piston and the exhaust hardly touches the clay. We had made custom solid lifters and also tried using regular pumped up lifters..No dice. We used a milwaukee probe and watched through the spark plug hole the clay just get pushed away from the intake side.
Wouldn't it have bound and not turned over well prior to not getting cut?? Taking a hundred thousandths off did nothing? How???
