no idea
spammy123
70
Jan 26, 2008
stow, Ohio
ok well it started after i changed ignition wires a while back to head out to the track. on the way up there the car started acting up as if the ignition wires went bad, startred spitting at boost all that bs. ended up replacing the coil pack because it was chipped and looked bad. at the same time i put 550cc injectors in because i had the fuel rail off anyways and figured id get the coil pack fixed and be able to give it a good tune with dsmlink. the car no longer had idling problems with the 550s in as far as bogging when i revd at idle and stuff like that. however it still spits when i hit boost out driving. this is with the stock ecu no dsmlink. i did a boost leak test and did find a leak from one of the injectors but resolved that and thought that would solve the spitting. but of course it didnt. i had my tuner plug plug into the dsmlink and try to give it a tune with the 550s but theres an issue somewhere preventing the car to run right even with a good tune. im assuming theres either another leak that is less obvious or there is a problem with ignition somewhere. even after a new coil pack/wires/plugs.:confused: this is just giving me a headache and any help would be appreciated.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
