No headlights at all
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
Hey guys, see if you can help me. The headlights dont work - Hi, lows.....nothing. Everything else does.
It doesnt get power to the headlight relay and when I look into the diagrams it seems that there's fuse, but i cant seem to find it. The diagram says Fuse 12.
According to this picture Fuse 12 is the horn fuse.....can this be?
Check #12 the 10A Taillights on Engine compartment fusible links. Make sure you're getting a good ground with your multimeter too!
Oh I cant believe they designed it like this, but yes the headlight relay is powered by the horn fuse on the solenoid side. I had pulled out the horn fuse earlier, because the horn was going off on its own.
Thanks again!
