Help! No headlights
Blaze4G63
191
May 30, 2008
NW, Washington
(1G)both my headlights are out along with my blower motor...i checked the fuses under the dash and im getting no power to my headlight fuse and the blower motor fuse right next to it!? what could be causing this i need headlights LOL also my wipers dont work either....please help!!!!!
THANKS GUYS
did you check the power feed wires running from the battery to under the fusebox? One of those may have came loose, disconnected or shorted in some way.
check your connections behind the fuse bus... since the fuses are right next to each other there may be an open right there causing them not to operate
Okay?...... Typically when people resolve the issue they don't just basically hammer the people who tried helping, they usually state what was wrong so that others can learn if they have the same issue. :idontknow:
