2G No dash power after shorting battery
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
I recently had a battery relocation and accidentally grounded the battery making it overheat and have no power at all in this thread. https://www.dsmtuners.com/threads/kill-switch-wiring.540040/
I fixed that issue with bending power cable off the chassis. Now I have battery power working but some things don’t work like rear taillight, all dash dose not work, car won’t start, and dash work for door light. Things that work cigarettes lighter and headlight and aftermarket gauges. I have check all the fuses they all look good haven’t really check big relays.
I even swapped ecu and nothing change been at it for about 5hr and I’m lost car is a 1995 early.
Honestly, some of that can be hard to track down, and overall, it's a huge pain. I would replace the entire dash harness so you have all fresh wires and no problems. If you decide to do that and need to find one, I have some spares, just send a PM.
Might have to do that as some point just wanted to see if anyone had any advice on stuff to check. I know the basic stuff for electrical
If you checked your fuse by looking at them you should check your fuses for continuity with a multimeter.
Can someone do me a solid and take a picture of there cabin fuse box 1995 talon tsi
So been testing everything and finally found were my issue is fuse #4 for amp keep blowing anyone have a diagram and more info on it
All the FSMs can be found in the maintenance guide under the resources tab.
I need some help reading this fuse 4 keep blowing
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
