2G NGR bov adjustment.
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
I just installed my NGR on my hard pipe kit. I am running 10 psi boost (I'm planning on bumping it up to 12-13 with Hallman mbc). I am trying to dial in my sweet spot, but I just keep getting turbo flutter. I read in the manual that for low boost applications that I need to hook up the little nipple in the back to the wastegate line?
If you are getting flutter then try to loosen it a little until it goes away, I had never used the other nipple and I don't have any problems, but if you still do then yes hook up the other nipple.
Hope it helps.
I would start at max loose and tighten as necessary. That's what worked for me. I adjusted it in a few turns and that was all. Also if you are going to pop it open and "void your warranty" you might as well replace all hardware with real SS hardware. Will keep it pretty for a lot longer. My PR greedy suffered from hardware rust big time. never again.
I run both springs BTW. I have done that on both of my knockoff greedy BOVs so far.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
