1glaserturbo
- 591
- 3
- Feb 12, 2005
Creve Coeur,
Missouri
Ok, here is my problem. I noticed a puddle (rather large) of oil underneath the oil pan so I decided to re-torque the bolts to the recommended level. Later that night I notice even more oil sitting underneath the pan.
My question is, where the bolts actually go into the pan, are they supposed to be perfectly level with the rest of the pan? I noticed on mine, the holes are actually raised a bit higher than the rest of the pan, is this normal? If not, I need a new oil pan, heh, and they aren't exactly cheap.
Thanks guys!
Chris
Thanks guys!
Chris
The raises are after the pan has been cleaned off to it's furthest extent, with the holes still raised. I've replaced the gasket 100s of times but still leaks profusely.
