new turbo...no boost!
boosted86
414
5
Sep 7, 2005
Weston, Florida
i just finished my b16g install yesterday, after i took it out for a spin i noticed that my vac wa READING ZERO and i wasnt building any boost, i also noticed that that my car wasnt going past 4k. now theres was a crack in the turbine housing ,could this be an anwser to my problem?and if so ...i have a spare turbine housung laying round from an mhi 20g, will this work? please some one help! thanks
Just covering the basics.......have you checked all of your piping? Sounds like the same thing that happened to me when I blew one of my pipes off.
Yea I think that crack will create a leak and you are loosing al your boost right there so I would look into replacing it you should also check your cooler piping you might have blown one are not tightened one and its leaking threw there. That's what happen to me when i installed my cooler. Also sorry but I dont know if the mhi 20g housing will fit.
Yes, if it's cracked, I would def check for boost leak, it's amazing how much trouble is caused by this problem.
