Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
If he has a stock front o2 then he should keep it and switch to the wideband signal going to the rear o2.
Unless you are running short on ECU inputs, there is no reason to not run a factory front O2 sensor. Having both it and the wideband gives you something to compare each one to.
What i did seem to notice is cylinder 4 is sounding like its arcing here and there and the idle goes weird (not all the time maybe once or twice a min)..I pulled off the spark plug wire(#4) a got a decent shock ...
Replace your wires with a new set of NGK's.
For future reference... if you think a cylinder isn't firing, you can go to the Misc tab in ECU Config and temporarily kill the injectors one at a time while the car is idling. If a cylinder isn't firing, you won't notice any difference when you kill that injector; otherwise the RPMs will drop and you will definitely feel it.
) Fixed that and now i can get it to go into closed loop and stay with out touching the gas ..The tps adjustment goes out of wack almost every-time i press the gas ,..Also goes out of wack every time i shut the car off and turn it back on ...
