2nd gear Pull log, new to link (v3 lite)
zerq
69
Mar 13, 2012
fairhope, Alabama
i plan on doing another Cruise log as mine was too large to upload, just trying to look for advice, if i did any of this wrong im sorry. my profile is up to date, no previous engine issues or leaks.
I added my Evo 8 560cc injectors the day i installed Link with included ECU from the classifieds here. i think one of my injectors may be bad/clogged, no time to pull it apart until tmrw, when i go into link and shut off each injector 1 by 1, the 2nd injector actually idles smoother off. if i directly pull the plug off of the driver side middle injector, it does the same thing.
im new to all this, so if i sent the wrong info just let me know and ill try to get out the right file.
From 6271 you were getting 2.8* of knock retard and your ThrotPos was only up to 87% so I would see about adjusting the TPS and seeing how tight the throttle cable is. My ThrotPos is only at 90% but I am trying to get it to 100% I know anything over 90% is considered WOT.
Your airflow was consistent so it doesn't look like you have any boost leaks.
