logged 2nd to 3rd gear pull
spidy3
192
4
Jan 20, 2005
upstate, New York
i couldnt get my logs to my comp. so i guess i'll have to just write them down for now....
did a pull from 2nd to 3rd with no lift to shift
2nd gear pull
rpm........knock.......timing.......O2...... TPS....... Fuel trim Hi
3562......... 0 ........... 16* ..... .86v .....100%..........137%
5343..........3............ 20* ....... .86v......100%...... "
6500.........13.......... 17*......... .86v......100% .......... "
7093 ........12..........14*.......... .86v......100%.......... "
3rd gear....
5093..........10..........15*.......... .86v.........." .......... "
5500..........15..........16*.......... .86v..........".......... "
5625..........16..........16*.......... .86v..........".......... "
7 or 8 data points throughout 2 gears doesn't say much. But WhiteTsiAwd is correct, you need to go richer to get rid of that knock.
First, you need to try and get more out of that logger. Are you running the Pocketlogger program?
What are your Hi SAFC settings?
After fixing the logger and adding fuel, make a pull in 3rd gear from about 2.5k to redline logging rpm, timing, knock and airflow and post that up. :thumb:
