LOLVTEC
- 286
- 0
- Dec 1, 2011
Los Angeles,
California
I can't see your log since I'm on my phone. But do a tps adjust to correct your 1+ tps. Also make sure on your maf tab you have it set on stock 1g maf. ill pm you my number and walk you through it. You might have to mess with your dead time.
edit got on my pc.
okay first off since you're running a maft your maf comp slider is wrong. you need to put it as stock because you don't have a direct wire from your gm maf to the pigtail, you have it running off the maft.
you have a dtc most likely because you have your maf settings wrong, clear that.
and why is your target idle so high are you running 272's?
1st change your maf comp slider to stock
2nd clear your dtc
3rd put your target idle back to 750 or 800 (if you do go for 800 adjust the offset)
4th do another tps adjust
5th should your car turn on and idle what is your afr. should be 14.7 but since your doing NBS it will fluctuate from 14.4 to 14.9 aim for closed loop operation
6th let it idle for a bit (warm up to 180) do a combinded ft and click use template, smooth it out.
just do a log all i'll fix it for you.
edit got on my pc.
2nd clear your dtc
lots of things to check try and fix ...
..Took it for a little drive around the block ,cel light came on on a pull ..dtc shows 2 codes 0014 throttle position circuit malfunction and 0041 injector circuit malfunction
