420a-t
- 609
- 4
- Jun 13, 2005
Idaho Falls,
Idaho
I decided to do a compression test on my new motor today, and I have some questions. Here's the results from the dry/wet compression tests:
dry compression Wet compression
cyl1 142 155
cyl2 100 175???
cyl3 145 155
cyl4 145 155
WTF is up with that? Since it went up with oil in the cylinders, can I rule out valve seals, cam timing, and blown headgasket? The reason why I tested the motor was I was pushing coolant when I was in boost. So, I tightened down my studs to 110 and wanted to see if that helped, and I find this.
Another problem I saw when using my air compressor to see if I could tell where the air is going was on cylinders 1 and 3 would leak air into one another (meaning I could add air into cyl.3 andcover the spark plug hole in cylinder 1 and feel air). I was adding air while ensuring it was at TDC by turining the crank a little every way and it was.
The motor is a 2.3 9:1 comp with only 200 miles on it. One of my big questions is there still time for the rings to seat better (if that's the problem at all), or for the enigne to break in?
Am I screwed, or what/where do I go from here? What else can I try?
Thanks
cyl1 142 155
cyl2 100 175???
cyl3 145 155
cyl4 145 155
Thanks
