new DSM owner
counttripula
May 21, 2014
stuart, Virginia
hello everyone im about to purchase my first eclipse is a 97 eclipse rs with 125k miles on it the guy im buying it off from say's it needs a fuel pump and a battery.
The car has been sitting since 2007 what would everyone recommend me doing first to it i know a tune up. but if yall bought a car that has been sitting for 7 years what would yall do?
I would change ALL fluids. How much are you paying for this RS? I would take the money and put it on a 1G turbo but that's just my thought. ;)
Hello and welcome!!! There are alot of helpful members here that will gladly chime in. I would do the normal tune up (plugs, wires, fuel filter, air filter for sure), check/replace the belts and hoses as needed. If it needs a pump, consider what you will be doing in the future. Most of us bump up the fuel pump to a 190 LPG or a 255 for turbo cars. You car is a non-turbo car correct? You can browse the 420A section that is on here for more ideas. Also change all the fluids wouldn't be a bad idea of course also (trans, motor oil and coolant). Little things like wiper blades and such will be forgotten until needed so good idea to do them now too. Look the tires over well since it has been sitting. Don't want any dry rot. Check your brake fluid and PS fluid too. Glance at the rotors and see if you can tell if it is needing brake pads. If you see any grooves in your rotors then its time to have them turned or replaced. All are general tune up stuff but sitting for 7 years they all need checked or replaced. I started out in a 3G Eclipse then got into the turbo models. Good luck on the new car and again, welcome. :talon:
Link to 420A section:
http://www.dsmtuners.com/forum/dsm-420a-frequently-answered-questions.106/
thanks for the welcome im going to replace all the fluids and yes its a non turbo im not looking into the whole turbo deal for a while.
well im happy to say she sprung to life for the first time in 7 years now to do the tune up and over haul.
Alucard: I paid 600 for the car an i dont like the 1st gen eclipse
Hey great news. Glad its living again!!!
Welcome! Make sure you double check those ball joints! They are tricky on 2gs and I think there is a recall for them! Enjoy
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
