2G new owner new dsm
YoungNoob
Feb 9, 2022
Binghamton, New York
Hi guys! I'm 17 and just bought a 97 eagle talon tsi.
My waste gate was not opening properly on my 16g setup and i was just running off of spring pressure. I'm porting the waste gate but is it worth it?
Should i do timing, water pump etc? I'm around 440 crank right now by doing math with my tuner but no clue hence the over boosting.
Welcome to dsmtuners. Please create a profile for the car.
You say you're overboosting? As in the car hits waste gate pressure, then slowly continues to rise from there? What is the car doing exactly?
Again we need the profile. Hard to help if we don't know what's been done to the car.
You should definitely do your timing and pumps as often as is recommended. I'd start with either a profile of the car or rebuild the wastegate, not port it.
I gotta ask, rebuild the wastegate? What does that mean? Unless you're assuming OP has an external. Which we would know if OP would fill out a profile.
Do you know the person that you bought the car from? If not, I would start with the PMs (oil change, timing belt, etc.) before i would port the waste gate. If yes, do you know if the PMs were done on a regular basis? I would focus on ensure the car is maintained well before putting more money into performance.
Putting in new parts like the diaphragm, valve seat, actuator, flapper, flapper arm, bushing, and clips.
Diaphragm isn't serviceable on an internal. Neither is actuator (arm?) And there is no valve seat.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
