New DSM Owner!
jwilt2008
111
Apr 25, 2010
Novi, Michigan
Just picked up a 1995 talon tsi awd. It has 3inch downpipe, exhaust, and intake done to it. It also has all new belts and fluids . I was wondering if u can run a FMIC on a stock turbo with out any problems and if it would be worth it? Or i am open to all advise i just want to know where i should start with other mods...any help would be nice thanks :thumb:
The reason he posted that wasnt to amuse himself it was to show you the proper upgrade path for a 2g. Follow that upgrade path and you will be golden. The specific answer is yes but why would you want to, you will see minimal gains as opposed to say, an exhaust.
Yeah thanks guys ill just do some more reading....thanks for the link
Welcome.
I was messing around COD or I would've put a little more into it.
That is the upgrade path like the previous poster said.
I would read it and learn it.
I suggest you go with a FMIC instead of just hard SMIC piping if you plan on upgrading the turbo eventually.
Install will be much either with a 14b or such also.
If you need anymore help you can PM me or use the forum.
There is also a search button.
Welcome.
Thanks i plan on upgrading the turbo in time... so i thought if i get a FMIC i can get it out of the way just wanted to make sure if it was fine to run on a stock turbo set up i know this has been answered before but do u have a link to a cheaper fmic?
ETS (95-99) 2G DSM Eclipse/Talon 7" Street Intercooler Kit DSM02IKStreet
ETS makes great intercoolers and a decent price for the quality. When you order it get on with a 1g BOV flange then buy a 1g BOV because the 2g one is plastic and leaks under increased boost.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
