TajMan
- 70
- 1
- Jan 20, 2005
Salt lake City,
Utah
The car is a '90 Talon Tsi AWD.
Ok, well I didn't JUST install a new clutch, I've been through an incredible ammount of problems with this car. I bought it already disassembeled, just a shortblock in the car. I've been through 2 engines, 4 times dropping the tranny, 4 starter motors, etc. So now I finally have it running. The last time I put the engine/tranny in the car, it was with a new clutch disk, new pressure plate, new throw out bearing, and a re-ground flywheel.
Well its all together now, and the problem its having is the clutch won't release. The system has been bled, no air in the lines, and the slave and master clyinders AREN'T leaking. I don't know what the problem is. The pedal just seems extra hard and you can't feel the clutch "releasing" when you press it.
I used to have a '90 GSX and I had to do a clutch job and I had the same problem! I had to drop the tranny on that car like 5 times before I got it working! Drop it once, grind more off the flywheel, re-install, drop again, grind more off the flywheel, etc. Finally to fix that one I installed a washer behind the "pivot" bolt for the shift fork and it moved things close enough so the throw out bearing pushed the fins in far enough when you depressed the pedal. (I know now I most likely had a bent shift fork that time.)
Its just so weird I'd have the same problem doing clutch jobs on two different cars of the same model. Is there some common issue I don't know about. What does everyone think is wrong this time? I'm not ready to drop the tranny any more on this car I just might have to sell it with its problem for less money.
