1G needing info on 1g cams
finaldaysofwar
Jan 22, 2013
boise city, Oklahoma
Hello I'm still learning a lot about the 4g63 and I need to know about the differences between all the types of cams from 90 to 94 how to tell them apart and what ones are swappable with what motors
90-92
intake 1.3974 lobe height
exhaust 1.3777
93+
Intake cams
NT & Turbo w/manual trans 1.3974 lobe height
Turbo w/ auto trans 1.3858
Exhaust cams
NT & turbo with auto trans 1.3858 lobe height
Turbo with manual trans 1.3974
Thank you, I have a 91 gs turbo auto with a little rust on a cam cause because the oil cap seal was no good but all it got was the cam. Just one and I have several other cams from other motors but I don't know what cams can go in that head
About any, turbo or non.
But it should be the intake cam that caught the rust, so it will have to be a intake cam to go back in
If you check the link I posted above, It has a listing and other links, on the ABC cams.
If you have just light surface rust, you can pull the cam out and wire brush or scotch brite the cam and clean it and re-install.
If it is pitted then it is junk.
