SRS Light on Needing Answers
TheFallenJosh
492
Mar 10, 2011
Knoxville, Tennessee
Ok guys When I did my Talon conversion I took out the entire interior and swapped airbags. Now that I have put the car back together my SRS light is on. I plugged all the sensor back up correctly but the light is still on. Now I had a question. The car I have is a '95 GS-T and I noticed the SRS unit itsself and the wire loom color is different from the car I got the passenger airbag out of ('97 GS-T) So could the fact that the passenger airbag came out of a different car with a different SRS unit be causing my troubles? I mean it all plugged up just the same, but the wire looms are yellow on the '97 and red on my '95 and the SRS ECU is smaller on the '97. So if someone has some answers for me that'd be great.
May need to take it to a shop that has a scanner that is capable of resetting the srs light. I had an issue with mine when I mistakenly unplugged the connector and had to have it reset with a scanner. $20 mistake but oh well live and learn
