1G Need injector help asap
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Well i screwed the pooch. I installed my pte 1000cc injectors and didnt realize the flared end made a difference and blew out all the seals i put on(stock). Is there something i can do without grinding this down or i am i stuck macining them and buying the stm kit?
I need to get it back and running asap
Pte injectors should use oem seals and shouldn't need to be machined to work.
By stock do you mean you are reusing the seals that were on your car previously? If so then reusing seals isn't ideal because they the seals become hard and brittle and they can shatter easily and can be a source of a bossy leak, you should be able to get a set at an autoparts store for pretty cheap
Yes sir. I'm still saving up to get the fuel line and regulator. I've had 1150's for 3 months and haven't been able to put them in the 90 yet
