Need help with clutch
d-meeks
53
Aug 17, 2011
burlington, Wisconsin
Hey guys my clutch has had its life and I need a new one so I was wondering what a decent clutch would be for a cheaper price don't have a lot of money and how to tackle the project. And what's happening is it was a tough clutch and then on my way home from work get in it push it down and then when I let off it was really weak so I'm assuming it's the clutch??
Thanks dillon
What kind of power will you need it to hold?
And youre saying its a heavy clutch pedal usually, but when you push it down now it doesn't feel as heavy? Or it doesn't return back to it's regular position when youre done shifting?
Yah once it returns back to its original position but it comes back slower and at a higher point an not has had to push down and no I have I went to go check it but I can't get the cap off gonna wait untill day time but I did notice te clutch pedel was leaking
I think the OP meant loss of clutch pressure. OP check your slave cylinder first and make sure it not leaking. Then if that OK check the clutch master cylinder for any leaks. If everything good bleed the clutch and see if you get any pressure back.
Alrighty thanks LOL and yah that's exaculy what it feels like is loos of clutch presse
I figured out that it's my master cylinder leaking any one know how hard that is to change and then is there and brand that is better than anther
Alright guys it is the clutch it slips under boost so I was wonder what a good clutch for the price and I don't want it to slip like this one did just under boost
Your grammar is atrocious. Please make an honest attempt at correct punctuation and spelling. As for your clutch recommendation request, I've had no problems with my ACT street disk and 2100 pressure plate. Your current setup will not produce anything beyond this combo's capabilities.
