need help with car stalling after throttle
blowngst
36
Feb 25, 2010
harrisburg, Pennsylvania
hey guys this is really becoming a nuisance. car runs fine no hesitation or anything like that. BOV is recirculated so its not that. it seems that when i am more than 20% throttle or more than 10HG/vacuum on the boost gauge and put it in neutral the car will stall out. BUT when i free rev it, it does not stall!?!?! I personally think this is fuel related and not a boost/vac leak but i could be wrong. i have a SAFCll with upgraded injectors. please give me some ideas!:confused:
Check your MAF, shit happened to me today, I opened the hood and the pipe had wiggled out.
funny you said something about the fuel pump! i do notice a loud humming noise on hot days. i just really need to track this down but i really need your advice/help guys!
checked for leaks today and could not find anything. messed with that safc in the dec. air and there was no change. please i need more advice.
The fuel pumps always like to make that noise. Thats how you know its working. Is your car mainly stock? Has it had a tune of some sort? Not having a tune for larger injectors could cause this. The motor could be getting too much gas when you let of the throttle.
Did you recently relocate your battery?? Could be a bad ground.
Could be a front 02 sensor going dead, Could be your ISC or TPS isnt set right.
Your car is dumping fuel when you go off throttle.
Set your ISC, TPS.
Check your Grounds
Test your 02 sensor
Report back.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
