need help with 50trim install!!!
dSmgs-T
518
8
Oct 26, 2007
harleysville, Pennsylvania
just got done taking my t/28 out yesterday, and im picking up my 50trim today from getting ceramic coated. now i have a feeling when i put this on im going to run into problems(first turbo swap myself) from what i understand with this pte scm 5031e it will eliminate my water pipe and i will need a bolt to plug the hole, is this correct? also i have a question about hooking up the ex WG correctly and which valve to use(38mm tial) any help you guys can give me on how to properly put this in will be great!
You won't eliminate the water pipe itself. There a line that goes to it that you just need to do something with since it won't be used any more. You use the bottom port on the wastegate. Youmight have to dent the water pipe also. I didn't have to but that is because my SBR exhaust manifold makes the turbo sit further from the block.
