pics of 50trim install...w/ ?'s about water lines
dSmgs-T
518
8
Oct 26, 2007
harleysville, Pennsylvania
thought id share my new setup, finished it today but im waiting on a FMIC. im using a 2g manifold ported, pte 5031e, and a custom JMFab o2 with 38wg. only thing im not positive to finish this up is how to do my water lines(how to properly loop them or block them off)
thanks guys!
can i really just take the water feed off and use the longer water return line and loop those together?!
I will soon be installing a 50 trim myself so all that I need to do is to run the old two lines connected into one line or what.
If I just capped the send line then would I have to put a bolt in the block where the return line goes to block that one off. I would rather do it that way to make it look a little cleaner.
If you fill the cap with RTV before installing it, it won't explode.
Then if you weld them and you have a water cooled turbo in the future then you need new lines. Just loop it and be done with it.
Thats true. For me it doesn't matter since the 50 trim I have is oil only and the next/last turbo I buy will be oil only.
Another clean way to do it would be put n/t parts on it. And then if you got a water cooled turbo you just have to swap the turbo pieces back on.
