need help trouble codes affecting dsmlink operation
rmk22092
Aug 30, 2009
lac la belle, Michigan
Ever since I installed dsm llink v3 I am getting three error codes that are effecting the ability to tune with the program, running super rich at low rmp's and then getting alot of knock at higher rpms, adjusting the fuel does not seem to effect the knock issue. I have the dead time and the global fuel set pretty close
Code 12 Volume air flow circuit malfunction
Code 13 Intake air temperature circuitmalfunction
Code 25 Barometric pressure circuit malfunction
I did not hae any trouble codes before installing the link and I have tried swapping out the mass air flow sensor with one that was for sure working properly and that had no effect.
Not sure if this is posted in the right place, I'm new to this site and product
heres a third gear pull
ill take the ecu back out and inspect everything
pins all look in good shape but found the terminal for the MAF was loose in the connector so ill replace that and give it a try
