Need clutch help
95whitegst
537
Aug 14, 2009
lancaster, Pennsylvania
Ok so the other day my fluid drained out of my clutch fluid resevior so I bleed the lines filled it back up an it was fine now whenever I drive the fluid drains out to almost empty and I have to fill it up it only does this when driving if I sit in my driveway and pump the Clutch the fluid level doesn't budge any ideas guys
Look at the boot of the master cylinder. Go underneath the dash, by the clutch pedal you'll see the master cylinder coonected to the top of the pedal, check the rubber boot and see if it's wet. If it is, the seal is worn and the master needs to be replaced.
Next check the slave cylinder. This is located at the front of the tranny and engages the fork. Check THAT rubber boot and replace if it's leaking.
so i checked and no leaks....wtf am i missing were is all the fluid going ton i drove it around for a little and the fluid only went down a little bit but everynow and then the clutch pedal will stick to the floor
You are losing fluid somewhere. That fluid doesn't disappear. Something is leaking. Have a friend press the clutch and check the slave to see if it leaks. Also you need to recheck your firewall and your slave boots. IF you are leaking and losing pressure it's one of those.
