Calan
DSM Wiseman
- 7,250
- 401
- Jan 16, 2007
OKC,
Oklahoma
So this last weekend, I got the spare hood out and started working on my hood vents...since I don't have enough other projects going on.
They will consist of an aluminum frame mounted to the bottom side of the hood, and blended in on top with fiberglass and filler. The frame and mesh will be removable, and powdercoated black.
The frames are made out of 3/4" aluminum angle, cut and bent to form the lip of the vents. The two frames were then welded together and stiffened. In the image below you can see the fixture I built for shaping the frames.
I used the frame to mark a pattern on the hood, and then cut the opening using a drill, die grinder, and dremel. Once the opening was roughed out, I drilled holes and welded SS machine screws from the top to hold the frame. The heads were then ground down, and will later be covered with filler.
And, welding the screws to paper thin metal was almost impossible to do without burning them up. If you look closely, you may be able to see that I have two missing ones that need to be replaced.
Test fitting and adjusting:
I've still got a few details to work out (like how to do the filler and blending while allowing for powdercoat and still allowing the frame to drop out), but it's starting to come together.
Challenging project!
Good to know!
