my first attempt at an intake manifold
+2 I'd loveto see any info, be it a log, dyno sheet or a video of an incar pull
Thanks fellers for the compliments and input. Im totally happy with it weather it makes more power or not. :)
Sadly the car is still ###### 2 or 3 weeks out from being running.
I will deff post up pics an running videos as well as try and get a log or two up.
The nearest AWD dyno is 3 hours away so idk when it will get dyno'd.
YOu can always pull the viscous coupler out and replace it with a welded one or another viscous eliminator and dyno in FWD.I"ve found that the dyno shops that get more of the import market and do a lot of eclipse tuning tend to have eliminators on hand and you can put one in the trans in about a half hour 40 minutes ( alot easier than changing to a welded CD which also works for 2wd dyno pulls)
yeah for sure. the built auto trans i got has a welded diff already so i could easily do that but i would much rather prefer an awd dyno for true numbers.
but to just test the manifold obviously it wouldn't matter.
