My 1st log how's it look?
I dont got either of these SAFC, AFC, VPC, AFR, and I will make a WOT from 3k to 7k as soon as I get my car put back toghether what i thought was the bellhousing broke wasn't I guess it's internally, 3 outta 5 times it'd hunch like heck taking off and goin down the road only when ya were on the gas was a grinding/whistling noise.
Thanks
Ok so you are COMPLETELY stock, not even a boost controller?
Well you are running lean at idle. Rewire your FP, that might do the trick.
Once you get a WOT log, if you are seeing knock above 5 counts, TURN YOUR BOOST DOWN! If you are seeing just a few counts, you could leave it or turn it down a pound or two. If you are seeing no knock (like i'd assume from this log) you could turn it up a pound or two. You'd of course need a MBC to do any of this.
95TalonOwner said:
If you look at his pf, he has a N/T unless I'm missing something....
OMG Wowzers, thought his profile said 2.0 turbo motor, as in a conversion. Oops!
Well then, I think you should still do the FP rewire, and don't worry about the boost stuff I said! I don't even think you have a knock sensor. You should just try to get those fuel trims straightened out, there isn't much else logging is going to do for you.
yes he is correct I do got a N/T. i will see what I can do about the FP rewire and see if that helps me out any.
thanks
I ordered the rewire kit off ebay for 25.00. and for the knock sensor I know my car didn't come with one but I think their is a place for one. and I need to know how many wires are in the plugin for it so I can look and see if the harness is made for it.
I wouldn't waste your time or money on the knock sensor. Granted knock is bad, but not near as bad as it is under boost. If you want a knock sensor, make sure it costs at least a few grand and is connected to a 4g63t, and comes with a free car bolted to it :sneaky:
I would skip the knock sensor too. It's not like you have anything you can adjust for fuel/timing anyway, so if you are seeing knock, what are you going to do to fix it, not drive?
