DGajre777
DSM Wiseman
- 4,772
- 133
- Jul 16, 2004
Orlando,
Florida
Since this is a multiple question thread, it is in the newbie section.
1) Alternator and battery issues.
About 2 months ago my alternator was dying and was not charging the battery so I got a rebuilt one from Mitsubishi. I also re-wired the alternator with a 4g cable and a 100amp fuse on the firewall and kept the original factory alternator wire going from the battery to the fuse box.
Last thursday while I was driving with my A/C on, headlights on and CD player on (no subs), I saw the voltmeter go from 13.6 to 19.2 and then to 11.7 within about 1 second at 3500 RPMs and then the fuse blew. I replaced it and it worked fine.
Today I went to a glass shop to reseal my rear window, they left my headlights on for about 6 hours, so my battery was reading 8.3 volts when I got there. A guy in a truck jumped my car after we charged my battery for about 5 minutes. I drove for about 10 minutes (yes I know I'm not supposed to charge a dead battery with an alternator, but I didn't really have a choice), the alternator fuse blew on the alternator side.
So I go to walmart, pick up their SOSCHE (or whatever its called) brand 100amp fuse (since they were the only people open on a saturday night at 8 PM when I was rewiring my alternator and bought a wierd fuse holder from walmart). I charged my battery with a friend's big ass Chevy truck and then drove home for 30 minutes - and the fuse hasn't blown yet.
The alternator has a 1 year warranty and the battery was replaced at the same time the alternator was. The battery is a stock type (not Optima or other dry cell). One of the battery cells has some residue of battery acid, almost like the alternator was overcharging the battery.
I have all heat shields on, I have a big vent in my hood and since I have a 2G, I don't have the leaking power steering issue.
I'm guessing that I either have a short in the alternator or my voltage regulator is bad. I'm also thinking that maybe the cheap ass 100amp fuse is not really a 100amp fuse, but more like 85 which is why it is blowing when the alternator puts out more juice - would this be a possibility? Any other ideas?
2) Flywheel Bolts
My ACT flywheel came in today. I have a ACT 2100 with ACT's 6puck sprung hub disc, Mitsubishi TOB, clutch fork, master cyl, (slave was replaced 6 months ago), rear main seal, TOB clip, pivot ball and SS clutch line waiting to be installed.
I forgot to get new flywheel bolts. Do I really need NEW flywheel bolts from Mitsubishi when I do a clutch job? I couldn't find any information on it when I did a search.
3) Energy Suspension (not prothane) Motor Mounts 2G
They consist of lower mount inserts only, but come with 2 metal discs that look like huge washers. The univeral instructions state that it is for a "torque" mount. Does this mean it is for the front mount since it torques the most and takes almost 80% of an engine's load?
Any help will be appreciated, thanks!
2) Flywheel Bolts
