which motor mounts are these bolts for?
kneipperk
214
Oct 25, 2009
aurora, Colorado
I have 2 bolts that are marked "11" and 2 that are marked "10" Im assuming they are motor mount bolts but not exactly sure which mounts. They look similar to
Those marked "11" are for the rear motor mount bracket to engine block, the shank will be about 28.5mm long.
If I recall correctly, the only motor mount-related bolts with a "10" are those for the L bracket on the driver side that bolt it down to the mount on the front of the engine. These are quite a bit longer at 73mm.
