More Questions!!
GMDDSM
Sep 19, 2009
Lehi, Utah
I have a few more questions. I was running Vacuum Lines yesterday and Came across a few things that I myself coundn't find answers too.
Is this necessary? As some of you may know, I bought a 6-bolt swap basket case. These are extra parts.
This is all I can find for a Negative battery Cable. There has to be more to it right? I can't find anything cut, so I'm a bit lost.
The bottom of this Vacuum Cluster has openings? I don't believe I have any more available hoses.
Is the Evap canister supposed to have that empty Fitting neck?
The top pic is the bracket that goes from the block to the intake manifold, behind the engine. And as far as the negative battery terminal wire I think that there is only one wire as far as I remember, so throw a terminal ( I think that's what it is called) on the end of that wire, and you should be fine. The vaccum lines are out of my knowledge range, so I can't try to help you with that. Good luck
I guess I'll take a peak and see if he remembered to reinstall the bracket.
if you have to pass a visual emmisions check of some sort then you are probably going to need atleast some of the vacuum lines, charcoal canisted ect.
something that would help us give you good advise is do you have to pass a visual emissions test? another would be if you dont have to pass that test would you like to keep your emisions or not? most of the vacuum lines you see when you pop your hood are garbage and can be tossed. but it all determines on what you want to do and can do
Based on experience, Here in Utah, it depends on which shop you go too. I have had some search for the EVAP system and others have not. So to be safe, Lets say I have to have it.
Any suggestions on my Negative battery Cable? Is that all there is to it?
