- Thread starter
- #26
patman
5+ Year Contributor
- 107
- 62
- Oct 19, 2017
Budapest,
Europe
April 2023 update
I finished intalling the ducktail on the DSM, and it looks like it's always been there
At first I was nervous about the outcome, I've never seen a 2g with ducktail in my life. But the end result is even better than I expected, It really gives the car a unique look.
In the meantime I found a set of front Evo Brembo brakes for a good price. They are in a bit rough shape, but they were only about 400 USD, and they came with a set of Ferodo DS3000 pads with about 80% life left. I'm going to sell the race pads, and slowly start gathering the parts to rebuild the brakes and install them.
I also managed to get the car on the racetrack for the first time
It really is a blast to drive on the track, the tyres (Michelin Pilot Sport 4) are sticky enough, the 4g63 can easily pass an MX-5, or a Fiesta, and the OEM seats also hold me suprisingly well. It was all fun, until about 8 minutes later the engine started to knock on full throttle. I tought it was some kind of overheating, so I came off the track as soon as I could, and let the engine cool for about 1 hour. After that I went back for another session, but it started to knock again, and now it started almost immadiately
So I tried to push a bit, but then I let it go, and came back for cooling again. I tried it once again, but the same happened.
I cruised home from the track, checked the oil and the spark plugs but there is no evidence of damage. I went under the car, and everything is dry, it looks the same before I did the track day. I did a 2 hour drive since then and the car feels normal during cruising, no weird noises, no twitching, nothing, but the knocking is still there when I do a pull. This weekend I will do an oil change, I will also change the coolant water and add Motul Mocool to it, maybe that will help a bit. I contacted my friend who flashed the ecu and we will look into the timing too. I hope I don't have to take the whole engine apart after one afternoon on the track...
I will be back if I have update on the engine or the brakes, If anyone have other suggestions of what should I check, I will appreciate the help.
At first I was nervous about the outcome, I've never seen a 2g with ducktail in my life. But the end result is even better than I expected, It really gives the car a unique look.In the meantime I found a set of front Evo Brembo brakes for a good price. They are in a bit rough shape, but they were only about 400 USD, and they came with a set of Ferodo DS3000 pads with about 80% life left. I'm going to sell the race pads, and slowly start gathering the parts to rebuild the brakes and install them.
It really is a blast to drive on the track, the tyres (Michelin Pilot Sport 4) are sticky enough, the 4g63 can easily pass an MX-5, or a Fiesta, and the OEM seats also hold me suprisingly well. It was all fun, until about 8 minutes later the engine started to knock on full throttle. I tought it was some kind of overheating, so I came off the track as soon as I could, and let the engine cool for about 1 hour. After that I went back for another session, but it started to knock again, and now it started almost immadiately I cruised home from the track, checked the oil and the spark plugs but there is no evidence of damage. I went under the car, and everything is dry, it looks the same before I did the track day. I did a 2 hour drive since then and the car feels normal during cruising, no weird noises, no twitching, nothing, but the knocking is still there when I do a pull. This weekend I will do an oil change, I will also change the coolant water and add Motul Mocool to it, maybe that will help a bit. I contacted my friend who flashed the ecu and we will look into the timing too. I hope I don't have to take the whole engine apart after one afternoon on the track...
I had an EUDM NA Eclipse to begin with, so my fuse box looks like the one from the 4G64—it’s bigger and sits right in the way of the air filter when converting to turbo. I had previously rotated it to the side wall for the SMIC setup, which worked fine back then. But now it was blocking the forced air from reaching the engine.
![20250705_103659[1].jpg 20250705_103659[1].jpg](https://www.dsmtuners.com/data/attachments/747/747582-f22c2a44e6dba16b05d104986ea3f913.jpg)
![20250705_110724[1].jpg 20250705_110724[1].jpg](https://www.dsmtuners.com/data/attachments/747/747583-a977839de9e6fb65496c6b3607941591.jpg)
