Mitsubishi ASA (parts lookup)
12/4/2022
A member has commented the media fire link brought a virus. FYI he is using windows 11 if that matters.
If you want a copy of Mitsubishi ASA (north america), which is the program the dealer uses to lookup parts, you can download it HERE
after you install it, you will get a window for the configuration,
on the first page set the connection to no connection
click the common2 tab and click update configuration toward the bottom
make sure you have a check in the box for disable automatic online update
then once the main screen is open, double click where it says model (hylighted in green in the pic), it will pop up a window with all the models you can choose from.
eclipse D20 is for 1g
eclipse D30 is 2nd gen
eclipse spyder D38,39A is 2g spyder
After you choose the model you can click any of the 5 icons marked with the arrows. im sure you can figure it out from there
:tease::oops:
For some reason, the first 3 pictures aren't showing up, but the explanation is good enough for most of us.
Thanks for posting it!
Marty
it should be fixed now
Sooo, mine was in Russian when the installer opened and I put everything into a folder and now I have no idea what to do next.. mind helping out on how to launch the program?
This so what I have right now.. tried clicking on anything I could to get it to launch and no joy.
sorry i forgot about that, only the installer is in russian
just click this one, it will install and be in english
Did it not put a shortcut on your desktop to run the program?
if it didn't , open the M50 folder
then the PROG1 folder
scroll down to ASA.exe
right click it and select "create shortcut"
then you can cut an past the shortcut to your desktop or start menu or where you want
For some reason I cannot get ASA to function with the mmc-manuals.ru/downloads onto my Win11 pc. BUT....it works fine on a cloned hard drive with Win11.... suspecting I am going to have to delete, download again, and reinstall. I even have virtual clone drive installed and it's being picky. It's saying "sorry, this application cannot run under a virtual machine" and "hardlock error 14". First time in all the years I have had this issue.
I'm getting this error also. And the installer was in russian as above from the link posted. No workie.
I have a better copy than the version listed above. If anyone wants it, PM me and I'll shoot you a download link.
I've used the Mitsubishilinks.com download on secondary computers that I don't have a Mitsu dongle for, since around 2006 now. Goes up to 2008 models.
I have it running on a box that I just built, running Win11, before I migrate the official version over.
This is the only version here I was able to get working today.
UGGG I went to use CAPS or this ASA which has been on my computer for years with no problems and am getting the "hardlock error 14". Did you find a way around this?
I'm still using a Win10 box for work stuff even though I built a Win11 box over the past winter as the Win10 unit is almost 10years old now.
That said, it works fine on my Win11 computer and I'm just having issues with my accounting/inventory software and Mitsubishi's current abortion "dealer software". Have you tried to use the MitsubishiLinks download and followed the guide to a "T"?
Hey guys, new guy here, just in the process of importing my first GST into the UK. We have real issues with Mitsubishi parts here since they pulled out of the UK a few years ago, I've been reading the thread about unofficial software that used to be a dealer parts searcher? All the options in this thread get blocked by virus detection etc, does anyone have a non virused link or better yet, the actual software?
Snailed it, thanks, back online. I wish it had newer Mitsus because I have a 2018 Outlander, OH well, beggers can't be choosers.
I could possibly send you the newer data folders I have. I did this in the past, copying the new data into the source folders, but it's been a long time now that I have an actual dealership dongle and run the actual OEM program.
If you have your computer locked down to that point, you may just want to use website data pages.
My computers are pretty well protected, yet I've been able to do the setup from mitsubishilinks for the last several decades.
sorry to bring up and old thread...
just wanted to share for those having issues win 11 and ASA installed from the .ru site.
this fix has worked on my laptop and desktop pc, no boxes used...
