1G Minimum Cylinder Hone - Grit
pieceofcloth
Supporting Member
581
573
Oct 6, 2019
Houston, Texas
I picked up a vehicle that was flooded. The motor was bored .20 & the cylinder walls are in great condition still. There is a very very minor build up which I was able to clean off with a soft scrub pad. I need to hone the walls with the smallest grit. Which grit do you guys recommend? Thank you all in advance
I'm not sure if the piston info matters but I have the :
Wiseco Pistons - Pro Tru Sport Compact Series (6625M855)
Pro Tru Pistons
1400H.D. w/ .225" Wall Tool Steel Pins
Replacement/Individual Piston
Recommended RingSet: 8550XX
Rings & Pins Included
Bore : 85.5mm
Comp Height : 35
Comp Ratio : 8.5:1
Dome Volume : -14
Gram Weight : 343
Rod : 150
Stroke : 88
I use a 320 grit flex hone. They also offer 400 and 600 grit if you need something even finer. 320 is what I use for glaze breaking and a freshen up. Motor seals up almost instantly. My machinist thought it was a bit coarse but my engines have never puffed any smoke after startup if even then.
Marty
https://www.enginehones.com/hones.html
I use a 320 grit flex hone. They also offer 400 and 600 grit if you need sonething even finer. 320 is what I use for glaze breaking and a freshen up. Motor seals up almost instantly. My machinist thought it was a bit coarse but my engines have never puffed any smoke after startup if even then.
Marty
salute bro, i appreciate your input :hellyeah:
Anytime! :thumb:
I spin one in a 1/2 drill and lube it with transmission fluid as I RAPIDLY go up and down in the cylinder. If you can lay the block on its side, the fluid stays on the hone better and its my preferred method. Put a piece of masking tape on the hone shaft to show you how deep to go and just hone for about 15 seconds and check your crosshatching. It should be pretty close to 90* and the faster you move in and out the better it will look like 90*. Work a little at a time and always with fluid.
10/4:hellyeah:
PM sent
It all depends on what ring pack you’re running. Different rings require a different ra and crosshatch angle.
I would have a shop with a pressure hone see if they can clean it up. A bottle brush or 3 arm hone follows irregularities and makes them worse.
I appreciate you bro -ty :hellyeah:
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
